W-BodyTech Technical Library
W-Body Tech Library
Start with your exact vehicle, then search verified W-Body repair guides, specifications, maintenance procedures and factory reference data.
Choose your starting point
Find the right information
Confirm the year, VIN, RPO codes, engine and transmission before using any repair procedure or specification.
30 resources shown
General Information & Maintenance
Identify the exact W-Body, establish a maintenance baseline and find the correct service information before repairs.
Engine Performance & Tune-up
Ignition, fuel, intake, exhaust and PCM diagnosis and performance information.
Ignition and Tune Up
Open this W-Body resource for verified applications, service information and related technical guidance.
Stage 1 Upgrade
ZZP 10.5mm wires and Accel 45k Coil Packs
Coil pack cleaning and preventive maintenance
3800 NA to Supercharged Top Swap Guide: L36/L67 & L26/L32
Engine & Engine Overhaul
Engine repair, gaskets, valvetrain, internal components and overhaul references.
Gaskets
Valvetrain
Torque Specs
Buick 3800 V6
60-Degree V6
LS4 5300 V8
Cooling System
GM W-Body Radiator Replacement & Cooling System Guide: 1988-2016
Drivetrain
Transmission and drivetrain references for fluids, filters, solenoids, wiring and rebuild planning.
Solenoids
Harness & Switches 4T65
Transmission Fluids and Filters
Torque Converters
Overhaul & Rebuild Kits
4-speed 4T65-E
GM 4T65E-HD Transmission
GM 4T60-E Transmission
Brake Upgrades
Brake service, component fitment and proven W-Body upgrade paths.
How to Upgrade W-Body Front Brakes with CTS-V Brembo Calipers
Tools & Equipment
Tools and equipment for maintenance, diagnosis and major repair work.
GM RPO code database
Decode GM Regular Production Option codes for engine, transmission, suspension and factory equipment.
Vehicles
Choose the exact Buick, Chevrolet, Oldsmobile or Pontiac W-Body generation.
